Inventor Fusion
Member
JWPepper
Message 1 of 3 (252 Views)
Copying/arraying items
252 Views, 2 Replies
06-28-2012 07:55 AM
If anyone can assist in telling me the correct procedure in copying/arraying the nozzle stiffners (90 deg's) on the attached screen shot I would be most grateful - I can only create new sketches at the correct plane/position and re-sketch the geometry each time (labourious) there most be a way to copy rotate solids? the other method I tried was creating a rough outline for the stiff then press pull to correct thickness & use assemble to position flush........but nothing I do will making the floating plate shown on the screen shot move using assemble
Board Manager
schneik
Message 2 of 3 (240 Views)
Re: Copying/arraying items
06-28-2012 10:08 PM in reply to: JWPepper
Try selecting the 5 faces of the rib/stiffener and using radial array?
Or,
delete the current rib and recreate it as a separate body. Then array the body and then boolean it into the main form.
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Member
JWPepper
Message 3 of 3 (237 Views)
06-29-2012 12:36 AM in reply to: schneik
Thanks, the first method I cannot select all the faces - namely the ones merged into the body only the outer faces
second works, I created new solid and in Boolean made new component which I never saw before.
Cheers
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
