Inventor Fusion
Active Contributor
Message 1 of 4 (302 Views)
Combining components for export/print
302 Views, 3 Replies
02-14-2013 06:35 AM
Full disclosure, I'm completely new to 3D design and I've spent a couple of weeks figuring out the right tools and learning some of the basics.  Now that the OSX crash is behind us, I can actually save and load files. :smileyhappy:
My problem is that when I export the attached model as STL, ReplicatorG only sees the main body and does not see the cavity and entry point for the latching mechanism.  When loading the STL back into IF, the entire object is there.  So, I presume the problem to be in ReplicatorG but my simple workaround is to combine four components into one body and export that way.  I've spent about an hour trying different things and searching the internet/forums and can't figure this out.
Ack! Any advice would be very much appreciated.
Active Contributor
Message 2 of 4 (292 Views)
Re: Combining components for export/print
02-14-2013 10:57 AM in reply to: LeonMF
I have a workaround.
  1. Export as STL
  2. Load into FreeCad
  3. Export as STL
  4. Load with ReplicatorG
I'll test the build tonight when I get home.
Board Manager
schneik
Message 3 of 4 (288 Views)
02-14-2013 12:51 PM in reply to: LeonMF
Try using gmesh to open the stl and then save as STL binary. This is something we are looking into.
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Active Contributor
Message 4 of 4 (281 Views)
02-14-2013 10:11 PM in reply to: LeonMF
Actually, I was a bit wrong earlier.  To get it to work I had to do the following:
  1. Export as SAT from Inventor Fusion
  2. Open SAT in IF and export as STL
  3. Open STL in Freecad
  4. Save as native in Freecad
  5. Export from Freecad as STL
The print came out fine with some odd printing artifacts around the joints that probably shouldn't be there.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
