• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Member
    BillFargo3197
    Column forms
    174 Views, 4 Replies
    11-10-2012 09:55 AM
    I am trying to create a set of columns that have a sweeping rope like (vine) feature going up them. I've had no luck starting with a torus and trying to modify it. I've looked at paths and sweeps. Sweeps are close except they want to just revolve when I need the tubes to be wraping up the column. Not just circling around it. Any suggestions? I can easily draw it in 2D but would rather end up with a 3D element.
    Thanks in advance!
    Please use plain text.
    Board Manager
    schneik
    Re: Column forms
    11-10-2012 12:03 PM in reply to: BillFargo3197
    This is going to be hard to do today. What you want is a 3d sketch where you can draw on the surface of your column. the sweep along that shape.  Fusion does not have this ability. You can fake it with a lot of work.
    Create a surface that represents the outside of your column. create some offset workplanes and then daw some splines in these planes. split face on the surface. you proabably need to do several. then create a sweep aplong these split face edges.
    Kevin Schneider
    Board Manager
    schneik
    Re: Column forms
    12-05-2012 09:06 PM in reply to: BillFargo3197
    Were you able to make your forms?
    Kevin Schneider
    Member
    BillFargo3197
    Re: Column forms
    12-06-2012 06:03 PM in reply to: BillFargo3197
    Kevin,
    Not really what I was looking for. When I get time I will put a sketch up for what I'm looking for. Though I said like a vine, it could be just a spiral tube wrapping up the column. I looked at making a series of Torus' and then trying to slice them but I couldn't figure a way to do it.  When I get time, I'll loop back on it. I can make it appear graphically correct in CAD. I was just hoping to be able to actually create it in Fusion.
    Member
    BillFargo3197
    Re: Column forms
    12-06-2012 06:21 PM in reply to: BillFargo3197
    I realized that drawing a screw would pretty much solve my problem. Though I'm not sure how I would do it in Fusion, I think I can figure it out in CAD.  Another post made me think of it.
