Inventor Fusion
Active Member
Message 1 of 3 (210 Views)
Center of a cylinder
210 Views, 2 Replies
02-20-2013 12:50 PM
How can I position, or find the dimension to, the center of a cylindrical object? The only constraint that pops up with the assemble command is tangency. Trying to remember the radius and add it to the offset seems like a kludge.
Board Manager
Phil.E
Message 2 of 3 (197 Views)
Re: Center of a cylinder
02-22-2013 11:39 AM in reply to: kurt_steinke
Can you send a screen shot and/or data set?
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Autodesk, Inc.
Active Member
Message 3 of 3 (194 Views)
02-22-2013 01:50 PM in reply to: kurt_steinke
I figured it out. The "Align" option references the center of a cylinder relative to a plane (I don't know whether it works relative to a line or edge, though).
It would be REALLY nice if I could print a comprehensive manual. I can read MUCH faster than the videos can load, and that's IF I can guess the right name (or icon) of the function I'm trying to perform.
I think I've figured out how to place a hole and have it stay on the part. The problem occurs when the dimension to an edge is less than a whole unit (e.g. .5 in). When I type the decimal point, the location of the hole snaps to the edge (offset of 0), and then, more often than not, when I type the following digit, the hole moves that far OUTSIDE the part regardless of whether I input a leading minus sign. The "workaround" is to type the first digit very quickly after the decimal point, before the hole snaps to the edge of the part. Thanks,Kurt
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
