I'm going through the AU2011 fusion Level 1 document (MA5528.pdf - page 34
Window select the top portion of the bracket.
Window pre-selection doesn't work!
Fusion 2012 sp3 x64
Dave
Envisage
Solved by schneik-adsk. Go to Solution.
If you hold shift down does window select work?
Can you save, shut down Fusion and relaunch it? Does window select work?
Thanks with working with us to determine what may be the cause.
Thanks Kevin,
After a few days, I revisited this issue & found that I could window select. There must have been a glitch in the software when I was running through the AU documentation levels 1&2.
Dave Whiteley
Glad it is OK. We do know that there is an issue where window select stops working but we have been unable to get a reproducible case. Please let us know if you come across it again.
