Inventor Fusion
Member
Message 1 of 11 (2,456 Views)
Cannot copy / duplicate Body on Mac
2456 Views, 10 Replies
05-07-2012 11:58 AM
Perhaps I'm doing something incorrect; judging by what I can get out of the manual, if I right click on the body it should reveal an option to copy.  None is there.
If I select a body (it becomes blue) and select Copy from the edit menu, then paste nothing either.
I am very new to Autodesk and perhaps my PS brain is getting in the way for me to think of the browser breakdown like the 'layers' windows in PS.
Thanks for any help.
nf
Board Manager
schneik
Message 2 of 11 (2,453 Views)
Re: Cannot copy / duplicate Body on Mac
05-07-2012 03:12 PM in reply to: nf_able
Try this...
After you copy, click the top/root line in the browser to make sure that the object you selected to copy is no longer selected.
Then paste.
I think what is happening is that the copied object is still selected when you try to paste. We can paste something into itself so the paste is failing.
You should see a new line get added to the browser if the paste works. You can then use move component, or joints to position the item.
We know the current workflow is a bit rough and will be making it better in the future.  Maybe you could reply with a few thought on what you think would make it better or easier?
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Message 3 of 11 (2,442 Views)
05-08-2012 09:36 AM in reply to: schneik
Hey, Kevin, I was wondering about this very question earlier.
Suggestion: What would make the copy/paste easier to do is: The new, pasted body appears next to the body you've copied or...  smack in the middle of the screen (like when you copy/paste in Photoshop), or: if you can't paste because the original object is still selected, if a line appears on the screen that says: De-Select Original Body to Paste A Copy of It.
Frank
Member
Message 4 of 11 (2,441 Views)
05-08-2012 09:57 AM in reply to: schneik
Thank you Kevin, ui design is important to me and let's me know the creators care beyond just the functionality of a program and desire the user's connection and ease of use; it highlights one program as more inviting over others.
As far as copy / paste goes:
It just isn't avaliable for Bodies.  When I right click on the body to 'Create components from bodies' and it turns into a component, then I can copy and paste from the component.  But even then it's not as intuitive as it could be.  I need to click and highlight the top level file name in the browser to paste and then from a right-click only: the Edit - Paste doesn't seem to work.  Paste should be universal.  Even if the original component is selected I should be able to hit CMD-C for copy and CMD-V for paste and have a duplicate appear.  The program should know that the duplicate is identical to the current selected object and not replace it.  If a user was to copy object A and highlight object B and click paste, it should replace object B with a duplicate of object A.  If a user were to copy object A and click in dead space then CMD-V, a duplicate of A should appear at that point.
Other thought:
There should be a hot-key for the 'pan' function, like PhotoShop (sorry to compare) holding space would let you pan the sceen around; when released the cursor reverts back to the function you had selected.
Also, the ability to move the toolbar as well as the browser is swell; I also like the way the browser can be windowed with the slight alpha on the grey background; perhaps this could be adjusted for user's desired opacity.
Lastly, the perspective cube should be able to be repositioned as the toolbar/browser are - its a bit of a distraction to have to move back to it.  Perhaps there is a way but it eludes me.
thx for listening,
nf
Message 5 of 11 (2,424 Views)
05-10-2012 06:31 AM in reply to: nf_able
To get around the absence of COPY/PASTE in Inventor Fusion, I've been using MIRROR (under PATTERN).  I usually only have symmetrical objects.  I guess, though, for non-symmetrical objects, you can mirror once, and then mirror the mirrored object to essentially duplicate the original.  (I guess you'd have to MOVE it somewhere along the line so that the mirrored mirrored object wasn't superimposed over the original.)
Message 6 of 11 (2,404 Views)
05-16-2012 04:28 PM in reply to: nf_able
Another way to work around the absence of COPY/PASTE in Inventor Fusion: Use Place (under Assemble).
1. Save the file (including the part you want to duplicate).  (In this case, we call it "file 1").
2. Delete everything except the part you want to duplicate.
3. Export this new file as a .sat.
4. Close the file.
5. Reopen file 1.
6. Under Assemble, hit PLACE.  (This only lets you place a limited number of formats, including a .sat.)  PLACE the .sat file.  It will appear in the middle of the composition.  Move object and repeat PLACE as needed.
Member
Message 7 of 11 (1,505 Views)
04-08-2013 02:37 AM in reply to: nf_able
This glitch is really frustrating.
Employee
Message 8 of 11 (434 Views)
01-26-2014 12:38 AM in reply to: nf_able
Spoiler
I think this is the solution!
While I am not on a Mac, I am assuming that what I discovered will work for both Mac and Windows PCs. If you right click in the browser on the object you want to copy, and then hit Ctrl+v with your cursor in the drawing area, I found the object I wanted pasted in concurrent space with (overlapping) the original obect. So then I just used the Move & Align tools to get the copied object where I wanted it.
Please click on "Accept as Solution" button below, and Reply too so I'll know if that did the trick for you.
Wm
New Member
Message 9 of 11 (231 Views)
03-07-2014 03:56 AM in reply to: schneik
Hi There- I've been struggling for 2 days now to figure out why copy and paste wasn't working on my mac. I've tried everything possible and it just doesn't work. I can select copy components, but then when I try to paste them it doesn't happen. It seems to believe it has, because the possibility to "repeat paste" comes up. It's such a fundamental action that I just couldn't believe that it wouldn't work- but looking here it seems that other people find the same. WOW! Also would be great to be able to pattern sketch elements (like rectangles) but this doesn't seem possible either. Have to draw repeated elements individually. Amazing!
New Member
Message 10 of 11 (228 Views)
03-07-2014 05:38 AM in reply to: AjayKay
OK- worked it out copying now. Still would like patterning in sketch mode.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
