• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Member
    Cannot copy / duplicate Body on Mac
    1142 Views, 6 Replies
    05-07-2012 11:58 AM
    Perhaps I'm doing something incorrect; judging by what I can get out of the manual, if I right click on the body it should reveal an option to copy.  None is there.
    If I select a body (it becomes blue) and select Copy from the edit menu, then paste nothing either.
    I am very new to Autodesk and perhaps my PS brain is getting in the way for me to think of the browser breakdown like the 'layers' windows in PS.
    Thanks for any help.
    nf
    Please use plain text.
    Board Manager
    schneik
    Re: Cannot copy / duplicate Body on Mac
    05-07-2012 03:12 PM in reply to: nf_able
    Try this...
    After you copy, click the top/root line in the browser to make sure that the object you selected to copy is no longer selected.
    Then paste.
    I think what is happening is that the copied object is still selected when you try to paste. We can paste something into itself so the paste is failing.
    You should see a new line get added to the browser if the paste works. You can then use move component, or joints to position the item.
    We know the current workflow is a bit rough and will be making it better in the future.  Maybe you could reply with a few thought on what you think would make it better or easier?
    Kevin Schneider
    05-08-2012 09:36 AM in reply to: schneik
    Hey, Kevin, I was wondering about this very question earlier.
    Suggestion: What would make the copy/paste easier to do is: The new, pasted body appears next to the body you've copied or...  smack in the middle of the screen (like when you copy/paste in Photoshop), or: if you can't paste because the original object is still selected, if a line appears on the screen that says: De-Select Original Body to Paste A Copy of It.
    Frank
    Member
    05-08-2012 09:57 AM in reply to: schneik
    Thank you Kevin, ui design is important to me and let's me know the creators care beyond just the functionality of a program and desire the user's connection and ease of use; it highlights one program as more inviting over others.
    As far as copy / paste goes:
    It just isn't avaliable for Bodies.  When I right click on the body to 'Create components from bodies' and it turns into a component, then I can copy and paste from the component.  But even then it's not as intuitive as it could be.  I need to click and highlight the top level file name in the browser to paste and then from a right-click only: the Edit - Paste doesn't seem to work.  Paste should be universal.  Even if the original component is selected I should be able to hit CMD-C for copy and CMD-V for paste and have a duplicate appear.  The program should know that the duplicate is identical to the current selected object and not replace it.  If a user was to copy object A and highlight object B and click paste, it should replace object B with a duplicate of object A.  If a user were to copy object A and click in dead space then CMD-V, a duplicate of A should appear at that point.
    Other thought:
    There should be a hot-key for the 'pan' function, like PhotoShop (sorry to compare) holding space would let you pan the sceen around; when released the cursor reverts back to the function you had selected.
    Also, the ability to move the toolbar as well as the browser is swell; I also like the way the browser can be windowed with the slight alpha on the grey background; perhaps this could be adjusted for user's desired opacity.
    Lastly, the perspective cube should be able to be repositioned as the toolbar/browser are - its a bit of a distraction to have to move back to it.  Perhaps there is a way but it eludes me.
    thx for listening,
    nf
    05-10-2012 06:31 AM in reply to: nf_able
    To get around the absence of COPY/PASTE in Inventor Fusion, I've been using MIRROR (under PATTERN).  I usually only have symmetrical objects.  I guess, though, for non-symmetrical objects, you can mirror once, and then mirror the mirrored object to essentially duplicate the original.  (I guess you'd have to MOVE it somewhere along the line so that the mirrored mirrored object wasn't superimposed over the original.)
    05-16-2012 04:28 PM in reply to: nf_able
    Another way to work around the absence of COPY/PASTE in Inventor Fusion: Use Place (under Assemble).
    1. Save the file (including the part you want to duplicate).  (In this case, we call it "file 1").
    2. Delete everything except the part you want to duplicate.
    3. Export this new file as a .sat.
    4. Close the file.
    5. Reopen file 1.
    6. Under Assemble, hit PLACE.  (This only lets you place a limited number of formats, including a .sat.)  PLACE the .sat file.  It will appear in the middle of the composition.  Move object and repeat PLACE as needed.
    Member
    04-08-2013 02:37 AM in reply to: nf_able
    This glitch is really frustrating.
