Inventor Fusion
Member
good-ham
Message 1 of 12 (1,533 Views)
Can you move a hole?
1533 Views, 11 Replies
02-16-2013 09:06 AM
Hi. I'm in the process of learning Inventor Fusion, and I feel like this must be something simple that I'm just missing. I've tried everything I can think of and cannot figure our how to relocate a hole once it is placed. I sketched a rectange, used Press Pull to turn it into a cube (solid), then made a hole. Once I OK it's size and placement I cannot figure out how to move it. If I need to change it's placement, I have to delete and re-create it. If I try to use move, I can only move the body. I found the question asked one other place, but it was never answered. Thanks for any help.
Greg
JDMather
Message 2 of 12 (1,518 Views)
Re: Can you move a hole?
02-17-2013 09:57 AM in reply to: good-ham
There are some good videos here
http://au.autodesk.com/?nd=classes&filter_keywords=&chunk=100&filter_material=&filter_personal=&filt...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
kurt_steinke
Message 3 of 12 (1,477 Views)
02-22-2013 02:02 PM in reply to: good-ham
Moving a hole is fairly simple, just not explained well (if at all) in the videos. Expand the part in the browser (click on the little triangle to the left of the part's instance) with the hole in it. Right click on the hole you want to move. Click on the "Edit" option that drops down. Change the locating dimension(s). If the reference dimension to an edge of the part is less than 1, type the digit following the decimal point as quickly as you can after typing the decimal point so the hole doesn't snap to the edge of the part, and then OFF the part by the amount of the digit. Alternatively, you can type the digit, and then insert the decimal point.
Member
good-ham
Message 4 of 12 (1,473 Views)
02-22-2013 06:08 PM in reply to: kurt_steinke
Hi, Kurt,
Thanks for the reply. Are you using the PC version, by chance? I'm on the Mac version, and I'm beginning to think it is just hobbled to the point of being useless. The way you describe moving a hoe makes perfect sense - and is exactly what I would expect - but it doesn't apply in my case. There is no triangle by the body (see attached screen shot). The hole is listed at the bottom of the browser - and selecting it highlights the hole - but that's as far as it gets me. Right-clicking only provides a 'dissolve' option, and trying to grab the hole to move it - by the face, edge, center, anywhere I can try to grab it, in fact - does nothing. Selecting move and trying to move it moves the whole part. I keep coming back to that I must be missing *something*, because I can't believe a CAD based package wouldn't have a way to do something so fundamental. I have spent hours trying to figure this out, but am no closer.
Greg
Member
good-ham
Message 5 of 12 (1,472 Views)
02-22-2013 06:12 PM in reply to: JDMather
Thanks for the links. Great source of information. They didn't actually show how to move a hole that I saw - at least not in any way that my version had - but I did learn lots of other things. It looks as though the PC version is much more mature than the Mac version from what I can tell.
JDMather
Message 6 of 12 (1,450 Views)
02-24-2013 12:07 PM in reply to: good-ham
You might sign up for Fusion 360 Beta (search Google) - there is also a video on the AU website showing it working in Mac environment.
http://au.autodesk.com/?nd=class&session_id=11015
From the AU video it appears to be very different than Inventor Fusion and more Mac friendly.
Active Member
kurt_steinke
Message 7 of 12 (1,429 Views)
02-27-2013 07:56 AM in reply to: good-ham
Yes, I'm using the PC version of Inventor Fusion. It's become clear to me that even the PC version of Inventor Fusion is a "crippled" version of Inventor. Inventor Fusion's concept is good, but its implementation sucks. It was intended to work on and combine models created in virtually any CAD package (hence the title "Fusion"), but, unfortunately, was not implemented as a "high-end" CAD package itself. It had to be "history-free", since the "history" would differ among CAD packages, and "history-free" is the "lowest common denominator". Consequently, it lost some of Inventor's most powerful features: associativity between dimensions and the part, and the ability to create table-driven families of parts among others. Unless you NEED to import models from a variety of programs in a variety of formats, Inventor, rather than Inventor Fusion, is a better choice. Even Inventor version 1.something (the very first version to hit the streets, and, yeah, I'm that old) was a MUCH better and more powerful CAD package. Thanks, Kurt
Member
gary
Message 8 of 12 (1,243 Views)
05-22-2013 02:26 PM in reply to: good-ham
Did you ever solve this? I have the same issue! on mac
New Member
mbridak
Message 9 of 12 (1,141 Views)
08-01-2013 02:41 PM in reply to: good-ham
Yes, in OS X it seems a bit different. What I do is click the hole label in the browser on the left to select the hole. Then go to Modify -> Tweek Faces. Or you can select the side wall of the hole and then right click (if you have a mouse) and choose Tweek Faces. You should then be able to slide the hole around.
albertuan
Message 10 of 12 (916 Views)
10-28-2013 03:07 AM in reply to: mbridak
Thanks mbridak for the usefool tip.
When I try to move a hole with Tweak face in move method, movment axis are not alligned with model or with orign. Is there some way to align ?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
