Inventor Fusion
Member
gsenroc
Message 1 of 9 (2,343 Views)
Can't delete extruded solids ?
2343 Views, 8 Replies
07-28-2012 04:44 PM
Having been used Pro Engineering and Solidworks for years, I fall in love with this beautiful Inventor Fusion by the first try. But I'm now struggling with understanding some concept of Inventor Fusion. Please help me.
Here is the very simple problem but it trapped me inside:
I've made two cylinders, using "cylinder" or extrude. After making them, I want to delete the large cylinder which is extruded on top of the small one. Now the problem comes. I can't delete the large cylinder, there is an error saying "gap cannot be filled" when I hit delete. Yet I can delete the small one without any problem.
My question is: Why can't I delete the large cylinder directly and how can I delete it?
Board Manager
schneik
Message 2 of 9 (2,323 Views)
Re: Can't delete extruded solids ?
07-31-2012 10:14 AM in reply to: gsenroc
Deleting the faces you have shown does not leave enough faces for the solid to reform.
Since Fusion is not history based the capping face for the small cylinder is what is preventing you from deleting the larger cylinder.
The easiest thing to do is press-pull the large diameter to match the small diamater, then shorten the cylinder. We will look at how we can make cases like this easier in the future.
Thanks.
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
frankwu
Message 3 of 9 (2,313 Views)
08-01-2012 06:37 AM in reply to: schneik
How about this?  Create a rectangle offset from the double cylinder; then Patch the surface.
Extrude the smaller cylinder head through the recangle.
Then take the remaining shape (rectangle minus smaller cylinder) and extrude that through the doouble cylinder.
This should leave only the smaller cylinder.
On Mac, using Inventor Fusion 568.1.0.
Frank Wu
P.S. Inventor Fusion is my favorite program on this planet.  And now, with Mountain Lion on the Mac, you can preview an Inventor Fusion file in the finder!!! (Couldn't do that before with earlier combination of early IF and Mac OS).
frankwu
Message 4 of 9 (2,311 Views)
08-01-2012 07:00 AM in reply to: frankwu
A third way to get around this problem:
When you create the smaller cylinder (presumably by extruding a smaller circle), click on New Body. Then the smaller cylinder is a different object than the bigger cylinder.  And then just delete the bigger cylinder.
Member
gsenroc
Message 5 of 9 (2,307 Views)
08-01-2012 07:14 AM in reply to: frankwu
Thank you Kevin and Frank. The solutions work. I like the last solution best, which makes the other cylinder as a separate body. This allows me to delete it without effort and I can also group them later as component. If Fusion can remember my setting and let it extrude as a body every time as default it would be great! At the moment I have to switch it to body every time I want to extrude. Not bad but sometimes lack of efficiency.
frankwu
Message 6 of 9 (2,305 Views)
08-01-2012 07:22 AM in reply to: gsenroc
Glad to be of help.
One thing that it took me a while to realize is that when you create something like a cylinder, you (a) sketch a circle, and (b) extrude it. And (c) after you extrude the cylinder, the original sketch disappears.
But what it took me a while to realize is that it's not gone.  If you go back and maximize the Sketch folder along the left hand side, you will see your original sketch as the last item (though not visible).  Click on the ligh bulb and it shows up again in case you need to move or re-use it).
frankwu
Message 7 of 9 (2,304 Views)
08-01-2012 07:23 AM in reply to: frankwu
Ack.  Now that I re-read your post I see that my last comment might not be what you were talking about at all.  Sorry about that.  But good luck with your project anyway!
Employee
jeff.strater
Message 8 of 9 (2,215 Views)
08-13-2012 07:46 AM in reply to: gsenroc
The other approach that I would use (which is similar to the "create each cylinder as a new body") is to use Split Body.  If you start with the original geometry as a single body, you can use this command to split it into two, by selecting the plane of the larger cylinder as the splitting tool.  Then, just delete the body you don't want.  The advantage of this approach is you don't have to plan ahead to keep all the bodies separate.
Hope this helps.
Jeff Strater
- Autodesk
Member
gsenroc
Message 9 of 9 (2,206 Views)
08-13-2012 04:38 PM in reply to: jeff.strater
Thanks Jeff, this method works like a charm!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
