Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
CNC shops having issues with my .DWG
4 REPLIES 4
760 Views, 4 Replies
Hey there folks,
So I  created a part that I want produced by a cnc mill and long story short, that every mill I send the file to they cannot open it.
I tried sending them the 2013 .dwg and that didnt work so I sent the 2010 .dwg filetype and that is not working too. I attached the .dwg so you can see if I made some sort of mistake.
Please help! =D
4 REPLIES 4
SallyYang
Please tell us the version of fusion and your OS info.
And what product that CNC shop used to open you DWG?
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
in reply to: SallyYang
I am using windows 7 and Inventor fusion 2013, and the shop is using the programs solid edge, mastercam and gibbscam.
JDMather
I don't know if this has a bearing on the problem - but if I open in AutoCAD and run the List command it reports the geometry as Block Reference.
If I explode once then it lists 3D Solids which is what I suspect those programs are expecting.
Can you save in another format like STEP or IGES?
Do you have access to AutoCAD to explode the Block Reference?
schneik-adsk
Try sending them STEP files. Other DWG translators might not be up to date or have ropblems reading 3D data in the DWG.
Kevin Schneider
