Inventor Fusion
Active Contributor
engineerboy
Message 1 of 3 (198 Views)
Building an Assembly....
198 Views, 2 Replies
07-09-2009 10:55 AM
How does one go about building an assemble in Fusion? I've tried to copy-paste from another open file but, that isn't working. Any help would be appreciated.
Steve
Board Manager
schneik
Message 2 of 3 (198 Views)
Re: Building an Assembly....
07-09-2009 10:59 AM in reply to: engineerboy
Currently you can only copy bodies across documents. So in the source document expand the body folder, copy the body. Go to the target document, select the target component and paste.
-Kevin Schneider
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Board Manager
Jon.Balgley
Message 3 of 3 (198 Views)
07-09-2009 01:05 PM in reply to: engineerboy
A few other tips related to assemblies:
You can create a child "component" by right-clicking on the root (or other) component and selecting "New Component". This gives you a target to drag and paste.
Once you have more than the root component, you can drag bodies between them.
You can have multiple instances of the same component -- use copy&paste. (Only within a single document.)
--Jon Balgley (Autodesk)
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
