Inventor Fusion
Board Manager
schneik
Message 1 of 3 (827 Views)
Autodesk Inventor Fusion SP3 posted
827 Views, 2 Replies
09-30-2011 02:50 PM
The link is here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17893575&linkID=16915702
Notes on problems fixed:
3D Annotation
        • 3D Annotation
          • Crash if the face that a 3DA resides on is removed by a modeling operation.
Interoperability with Companion Products
        • AutoCAD
          • Inventor Fusion may hang/crash when copying a large number of AutoCAD 2D geometries to 2D Sketch.
          • The result of inserting two or more Inventor Fusion DWG files into AutoCAD may be incorrect.
          • Incorrect results may occur when copying a spline in AutoCAD and pasting it into a 2D Sketch of Inventor Fusion, if the spline was originally exported from SketchBookDesigner.
Modeling
        • CER: Inventor Fusion crashes when hovering over the edge of the hole after changing the counterbore diameter to be less than the hole diameter.
Sketch
        • Inventor Fusion will crash if "Ctrl + V" is pressed while creating sketch objects, if the clipboard is empty.
Translator
        • Catia
          • Spurious surface will be created when import Catia V5 file with solid
        • Pro/E
          • Inventor Fusion may crash when opening Pro/E assembly file with multiple parts
          • Model will be 10x enlarged if importing Pro/E model to Inventor Fusion.
        • Solidworks
          • Solidworks 2011 files are now supported.
        • STEP
          • CER: Crash when opening STEP file in localized version of Inventor Fusion.
UI
      • CER: Inventor Fusion crashes when entering a value for Extrude in Ribbon, then pressing and releasing the Shift key.
      • "Show Hide" and "Isolate" in graphic context menu will not work if multiple components are selected
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Board Manager
schneik
Message 2 of 3 (795 Views)
Re: Autodesk Inventor Fusion SP3 posted
10-03-2011 05:44 PM in reply to: schneik
IMPORTANT UPDATE!
The original posting had an issue and we have reposted the service pack. Please, if you have installed the service pack please uninstall it and install the newly posted version. You can ensure you have the right service pack by checking the "About Inventor Fusion" box from the help menu. It should read version "1.3.0.31."
To remove a service pack go to add/remove programs and choose the updates view. The service pack should be listed there.
Thanks.
-Kevin Schneider
Autodesk, inc.
Kevin Schneider
Message 3 of 3 (520 Views)
02-02-2012 06:35 AM in reply to: schneik
Just installed service packs 1, 2 and 3.  Rebooted.  Opened 2 Solidworks files.  Inventor 2012 SP1 failed to translate them by said they were 2011 files.  Fusion, when trying to open the files, opens a new document but it's empty.  So basically, nothing from Autodesk (AutoCAD, Inventor or Fusion) will open a SW 2011 file.
And no, I am not at liberty to post the files here.
Bill Schmid
AutoCAD Mechanical 2011
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
