• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Active Contributor
    Annotation Greyed out....
    606 Views, 3 Replies
    06-20-2010 10:56 AM
    It appears that one can not place dimension on geometry with the latest release.  The button all greyed out.  What gives?
    Steve
    Please use plain text.
    Board Manager
    Re: Annotation Greyed out....
    06-25-2010 07:27 AM in reply to: engineerboy
    Can you send me your file and I will try it?
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Active Contributor
    07-06-2010 03:34 PM in reply to: scott.sheppard
    Maybe I took a blow to the head but, I could have sworn that I could dimension sketches in the last release.
    Okay, so if I just make a rectangle and extrude it to some height, I can then dimension it.  Its a little bit different in thinking but, I can manage.  If that's the way its always been then, my apologies for sounding a false alarm.
    Steve
    Board Manager
    schneik
    07-12-2010 10:43 PM in reply to: engineerboy
    You can select sketch objects and they will auto-dimension. If you hold shift and select more than one you can dimension between sketch objects.
    -Kevin Schneider
    Kevin Schneider
