Inventor Fusion
Distinguished Contributor
Message 1 of 7 (426 Views)
A few issues....
426 Views, 6 Replies
08-11-2011 01:16 PM
FWIW, I don't mind beta testing software, but I'd like to be informed that I'm running beta software and be compensated for my time. This product is in no way ready for the AutoCAD community at large, IMO. Here is a short list of major problems....
  • Forget about jumping back and forth between AutoCAD and Fusion. You will lose work, solids & blocks will be renamed, insertion points will change, instances will be overwritten.
  • Fusion DWG and AutoCAD DWG are not the same. There seem to be dramatic differences that are not immediately obvious. I have serious concerns about what will happen if a user opens a file in Fusion. I foresee lots of calls to IT to restore files.
  • No keyboard shortcuts. If I were to sit down to think of a way to annoy long-time AutoCAD users, this would have to be number 1 on the list.
  • Reverse zoom. This is number 2 on the list of ways to annoy an AutoCAD user.
  • Move command is skittish. The triad jumps all over the place, and hitting the escape key halfway through a move leaves objects in odd locations rather than putting them back.
  • I seem to be unable to find a way to insert components in a Fusion drawing. I can draw them, open them, edit them, but cannot insert them.
Don't get me wrong, this is a great concept, I just don't think it is ready, and I believe that a half-baked release will seriously undermine the future of the product. People will try it, it does not work well, it screws up their files and generally annoys them. I have a hard enough time convincing people to try new commands, let alone entirely new design platforms. If it works as poorly as Fusion seems to, they may never give it a second glance.
Inventor is a mature platform with a lot going for it, but Fusion needed a few more hours in the oven. Again, this is just my opinion, and considering how high my hopes were, there may be a little bitterness there....
Employee
adsk_loren
Message 2 of 7 (412 Views)
Re: A few issues....
08-12-2011 09:53 AM in reply to: OwenWhitehouse
I forwarded this to the Fusion team. There are some limitations in the current version of Fusion.
I do have a couple of questions, though.
1) Are you opening the DWG in Fusion, or are you opening the file in AutoCAD and using thePlug-ins tab> Edit in Fusion command?
2) Have you looked at the Move videos on the Wiki help?
http://wikihelp.autodesk.com/Inventor_Fusion/enu/2012/Videos/move_edges.mp4
http://wikihelp.autodesk.com/Inventor_Fusion/enu/2012/Videos/move_geometry.mp4
http://wikihelp.autodesk.com/Inventor_Fusion/enu/2012/Videos/move_reorient_triad.mp4
Loren Jahraus
Subject Matter Expert/Technical Writer- Inventor Fusion
Board Manager
schneik
Message 3 of 7 (406 Views)
08-12-2011 10:21 AM in reply to: OwenWhitehouse
Owen,
I am sorry we did not meet your expectations. A few notes and Questions.
When Inventor Fusion opens and existing AutoCAD DWG we do not save it on top of the existing file, we make a copy. This should prevent any data from being lost. That said, it is true that we have to alter the file as we copy it, Fusion has real world units and needs to scale AutoCAD 3D data so that is matches these real units.
With the zoom direct and hotkeys being different we understand that the feel when moving between applications is not as smooth as it could be. We are working to make improvements in this area.
If you could share some models and your intended workflows with us we would very much like to understand how the tool was failing to work as expected. Please share what you can directly to our team using the feedback email alias: labs.iv.fusion@autodesk.com.
Thanks for talking the time to share you thoughts.
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
New Member
amynowacki
Message 4 of 7 (179 Views)
06-07-2013 08:57 AM in reply to: OwenWhitehouse
I am using release 14 and having some issues:
-the escape key does not work at all, I have no way to cancel a command once started......is my keyboard not working or is this new in r.14?
- key commands freeze up and sometimes crash the system - this is the way I draft and it is essential that I can continue to use key commands
please advise.
thanks.
Board Manager
schneik
Message 5 of 7 (161 Views)
06-16-2013 11:46 AM in reply to: amynowacki
What version of Inveor Fusion is this? We did not produce an R14.
Kevin Schneider
New Member
amynowacki
Message 6 of 7 (155 Views)
06-16-2013 03:56 PM in reply to: schneik
This is Autocad 2014..
Board Manager
schneik
Message 7 of 7 (142 Views)
06-18-2013 09:37 AM in reply to: amynowacki
To get AutoCAD answers please post to one of these forums:
http://forums.autodesk.com/t5/AutoCAD/ct-p/8
Kevin Schneider
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
