• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Distinguished Contributor
    3D mouse too slow
    466 Views, 6 Replies
    06-29-2009 01:15 PM
    Hello all, I'm really excited about this, my first issue is that my 3D mouse is too slow. Do I need special drivers for the fusion plug in? The mouse works fine in Inventor 2010, but when I open Fusion it is unacceptable.
    XP Professional SP2
    3D connexion mouse
    Rick
    Please use plain text.
    Board Manager
    schneik
    Re: 3D mouse too slow
    06-29-2009 02:28 PM in reply to: richardporqueddu6731
    You can increase the 3Dconnexion drive on a per application basis. Simply bring up the 3dconnexion control panel and turn up the sensitivity to a level that you are happy with.
    -Kevin Schneider
    Autodesk, Inc.
    Kevin Schneider
    06-30-2009 07:49 AM in reply to: richardporqueddu6731
    Yes, Okay Kevin.
    Thank you - the 3DX software is kind of cryptic.... With the software open I adjust the speeds and it works fine - but it's not that clear that the app has to be open first,
    Regardless, I shall tread on in fusion :smileywink:
    Rick
    bmdesign
    12-06-2011 05:02 AM in reply to: richardporqueddu6731
    Got this same problem with Autodesk Inventor Fusion Preview 2012 and 3DConnexion Space Explorer USB.
    I've set up the mouse to work very nicely in Inventor 2011, but with Fusion Preview 2012, it's more like unusable (slow) and does not react to changes in the 3DConnexion panel, for "Autodesk Inventor" profile. Does it need a profile of its own?
    The platform is Windows 7 Home Premium 32-bit, 4GB RAM, 2.0GHz Core 2 Duo Mac Mini (under BootCamp).
    The 3DConnexion panel really is confusing. First, I didn't realize it has application specific settings (pressing 'panel' on the mouse does *not* bring up the panel for the running application, but for Explorer - heh!).
    bmdesign
    12-06-2011 05:23 AM in reply to: bmdesign
    Unable to save edits to that post.
    The FIX is to use the Fusion Preview 2012's own little 3d mouse button (nice!). However, even then the performance is sluggish with the fastest speed. Not a GPU issue, NVidia GT9400 is fast enough and view change is instantenous with regular mouse.
    *Expert Elite*
    DarrenP
    12-12-2011 05:48 PM in reply to: bmdesign
    have you tried contacting the mouse manufacturer?
    bmdesign
    12-12-2011 10:47 PM in reply to: DarrenP
    I haven't contacted Logitech/3DConnexion on this. But I don't think it's primarily their issue.
    It can be the "experimental" version 10 drivers they have. Those work better for me otherwise. Anyways, Fusion is still in beta so I simply wanted to share the experience.
    By the way, my 4GB of RAM seems way too little (!) for Fusion. A friend said he'd "not approach it" without at least 6GB. I wonder where all those bits disappear nowadays (I've got 32-bit Windows so there's no chance of 6GB without re-buying an OS and re-installing that). I strongly believe Autodesk should have a look at the memory footprint as well before finally releasing Fusion. Otherwise, I tend to like it.
