Inventor Engineer-to-Order
Distinguished Contributor
ludesroc
Message 1 of 5 (136 Views)
run DLL
136 Views, 4 Replies
12-20-2012 11:30 AM
I'm trying to run a simple .dll from ETO but can't acheive anything!!!!
Here's my approach:
Copied the .dll is in the Design Files folder of the current project.
Tested in ETO --> Rule myValuesAdded As Number = ClassLibrary1.Class1.AddMyValues(5, 2)
I get --> No such method 'AddMyValues'  while calling (static) on ClassLibrary1.Class1
' Here is the dll...
Public Class Class1
  Public Function AddMyValues(ByVal Value1 As Double, ByVal Value2 As Double)
    Dim Result As Double
    Result = Value1 + Value2
    Return Result
  End Function
End Class
' Created a simple form to test the dll...it works just fine!!!
Imports ClassLibrary1
  Public Class Form1
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
      Dim Add As New ClassLibrary1.Class1
      TextBox3.Text = Add.AddMyValues(CDbl(TextBox1.Text), CDbl(TextBox2.Text)).ToString
    End Sub
  End Class
Any help would be appreciated.
Ludesroc
Board Manager
sanjay.ramaswamy
Message 2 of 5 (134 Views)
Re: run DLL
12-20-2012 12:19 PM in reply to: ludesroc
See if the attached helps (code from Jon Balgley's Potlatch presentation on this topic).
Intent rules:
      Rule cus1 = New vbclasslib.customer("Jon", "Balgley", "503-555-1234")
      Rule cus2 = New vbclasslib.customer("Jon", "Yelglab", "503-555-4321")
      Rule allCus = { cus1, cus2 }
      Rule allPhones As List
            For Each C In allCus
                  allPhones = allPhones + {c.phone}
            Next C
      End Rule
Sanjay-
ludesroc
Message 3 of 5 (128 Views)
Re: run DLL
12-20-2012 12:45 PM in reply to: sanjay.ramaswamy
Hi Sanjay,
When evaluating allPhones, I get this error...
Error - vbclasslib.customer
Error Message:
vbclasslib.customer
Rule Stack:
Part: Root
Rule: cus1
Design: ViewWindow
Source:
Part: Root
Rule: allCus
Design: ViewWindow
Source:
Part: Root
Rule: allPhones
Design: ViewWindow
Source:
Next C
End Rule
Part: Root
Rule: %%EVAL_TEMP_1
Design: ViewWindow
Source:
Uncached Rule %%EVAL_TEMP_1 As Any = allPhones
Are there any other steps to follow prior to run a dll from ETO?
1- I closed Inventor
2- Copy the dll in the design files folder (of current project)
3- Restarted Inventor
4- ...
Ludesroc
FarrenYoung
Message 4 of 5 (120 Views)
Re: run DLL
12-20-2012 02:02 PM in reply to: ludesroc
Try this instead
Public Class Class1
  Public Shared Function AddMyValues(ByVal Value1 As Double, ByVal Value2 As Double) As Double
    Return Result
  End Function
End Class
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
FarrenYoung
Message 5 of 5 (117 Views)
Re: run DLL
12-20-2012 02:07 PM in reply to: ludesroc
If you don't want static methods in your .net code, you could get an instance in your intent code.
  Dim instance As Any = New ClassLibrary1.Class1()
  Return instance.AddMyValues(5, 2)
End Rule
--Farren
You are not logged in.
Manufacturing Community
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
