Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
ludesroc
455 Views, 4 Replies
run DLL
I'm trying to run a simple .dll from ETO but can't acheive anything!!!!
Here's my approach:
Copied the .dll is in the Design Files folder of the current project.
Tested in ETO --> Rule myValuesAdded As Number = ClassLibrary1.Class1.AddMyValues(5, 2)
I get --> No such method 'AddMyValues'  while calling (static) on ClassLibrary1.Class1
' Here is the dll...
Public Class Class1
  Public Function AddMyValues(ByVal Value1 As Double, ByVal Value2 As Double)
    Dim Result As Double
    Result = Value1 + Value2
    Return Result
  End Function
End Class
' Created a simple form to test the dll...it works just fine!!!
Imports ClassLibrary1
  Public Class Form1
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
      Dim Add As New ClassLibrary1.Class1
      TextBox3.Text = Add.AddMyValues(CDbl(TextBox1.Text), CDbl(TextBox2.Text)).ToString
    End Sub
  End Class
Any help would be appreciated.
Ludesroc
4 REPLIES 4
sanjay.ramaswamy
in reply to: ludesroc
See if the attached helps (code from Jon Balgley's Potlatch presentation on this topic).
Intent rules:
      Rule cus1 = New vbclasslib.customer("Jon", "Balgley", "503-555-1234")
      Rule cus2 = New vbclasslib.customer("Jon", "Yelglab", "503-555-4321")
      Rule allCus = { cus1, cus2 }
      Rule allPhones As List
            For Each C In allCus
                  allPhones = allPhones + {c.phone}
            Next C
      End Rule
Sanjay-
ludesroc
in reply to: sanjay.ramaswamy
Hi Sanjay,
When evaluating allPhones, I get this error...
Error - vbclasslib.customer
Error Message:
vbclasslib.customer
Rule Stack:
Part: Root
Rule: cus1
Design: ViewWindow
Source:
Part: Root
Rule: allCus
Design: ViewWindow
Source:
Part: Root
Rule: allPhones
Design: ViewWindow
Source:
Next C
End Rule
Part: Root
Rule: %%EVAL_TEMP_1
Design: ViewWindow
Source:
Uncached Rule %%EVAL_TEMP_1 As Any = allPhones
Are there any other steps to follow prior to run a dll from ETO?
1- I closed Inventor
2- Copy the dll in the design files folder (of current project)
3- Restarted Inventor
4- ...
Ludesroc
FarrenYoung
Try this instead
Public Class Class1
  Public Shared Function AddMyValues(ByVal Value1 As Double, ByVal Value2 As Double) As Double
    Return Result
  End Function
End Class
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
FarrenYoung
If you don't want static methods in your .net code, you could get an instance in your intent code.
  Dim instance As Any = New ClassLibrary1.Class1()
  Return instance.AddMyValues(5, 2)
End Rule
--Farren
