When I try to copy some desing in Design Navigator throigh the opton "Save copy as" everything is good. I have new desing with old name in case using <%%DisplayName ("name")> _. Hovewer, when I try to change this name, design name in Design Navigator still old.
Any ideas?
One more issue.
If I try to replace design through changing parent design name, the target design still stay on the old place.
Please try closing the solution in Visual Studio, and then opening it again.
I know about that. But it's not the solution of problem.
Not easy to see with our designs, would you mind providing your design files for us to replicate the issue?
Amanda
It doesn't matter what files use. The problem is with VS. After renaming nothing changing with design names or them location. After reopening everything is OK.
I'm talking about display names, not file or design names.
