In this morning's "ETO Potlatch", Farren asked about using a System.Dictionary. Here is a simple example. Note that you cannot use "New", but you have to use CreateInstance.
Uncached Rule TestDictionary As List Dim map As Any = System.Activator.CreateInstance("mscorlib", "System.Collections.Generic.Dictionary`2[System.Int32,System.String]").UnWrap() map.Add(3, "Hello") map.Add(42, "Goodbye") Dim intentList As List Dim kv As Any For Each kv In map intentList = intentList + {kv.Key, kv.Value } Next Dim retList As List If (map.ContainsKey(3)) Then retList = retList + { map.get_Item(3) } End If Return retList End Rule
Thanks Mike!
Solved by FarrenYoung. Go to Solution.
Awesome! If only I had asked this question sooner. 😛
Thanks for this
