I'm trying to use factoryfiles as my member files. I'm overwritng the following code from the IvAdoptedPart design in Inventor ETO Serice 2013 R2:
< %%category("Inventor") > _ Rule cacheFileName As String = iv_pathFileNameOnly(factoryFileName)+ iv_pathExtension( factoryFileName) ' Directory where cached member file will be maintained ' Defaults to "Member Files" subdirectory of project directory. ' < %%category("Inventor") > _ Rule cacheFileDirectory As String = factoryFileDirectory
It instantiates and renders the files but every time I close the assembly if crashes inventor.
Has anyone else experienced this?
Solved by AlexKorzun. Go to Solution.
Did you try IvFixedPart? You will need to pass the full file name of the IPT.
