Inventor Engineer-to-Order
csuffell
Message 1 of 2 (67 Views)
Using ETO Studio against AutoCAD
67 Views, 1 Replies
01-24-2013 06:01 AM
For one of my applications I am using ETO against AutoCAD. Is it possible to use ETO Studio against AutoCAD or is it just Inventor?
Employee
JackGregory
Message 2 of 2 (63 Views)
Re: Using ETO Studio against AutoCAD
01-24-2013 07:22 AM in reply to: csuffell
Currently, there is no "debug" connection between ETO Studio and anything other than Inventor.  Getting this connection right is one of the hardest problems in supporting a debugger.  However, you can use ETO Studio to edit and work with libraries that are host indepedent, and you can of course use the editor for host-dependent stuff.  Since Studio runs an Intent kernel to compile source when there is no connection, you will get some of the benefits.
In addtion, Inventor now supports many of the original ISL (Intent Standard Library) primitives, so you can actually use Inventor to run rules restricted to these.
--Jack Gregory
You are not logged in.
Manufacturing Community
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
