Is there a way to setup UserLib in a different location then the default location? --> %Program Files%\Autodesk\Intent Professional <version>\Library\UserLib
The goal is to share user functions...
Hi
In the BIN folder of the installed application, there is an Intent.config file. For just in case, create a copy of this file.
Open it in your favorite XML editor, and change the following section in the desired way. The <Args> node may contain relative or absolute path to the library.
<Library name="userlib"> <Args>..\Library\userlib\</Args> <AutodeskProvided>True</AutodeskProvided> <Locked>True</Locked> <PrettyName>User Library</PrettyName> <Type>TextFile</Type> </Library>
For older Intent versions, the similar can be set in registry
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Intent\R<version>\Intent Common Files\Libraries\userlib
