Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
ludesroc
340 Views, 2 Replies
User Library
Is there a way to setup UserLib in a different location then the default location? --> %Program Files%\Autodesk\Intent Professional <version>\Library\UserLib
The goal is to share user functions...
Ludesroc
2 REPLIES 2
AlexKorzun
in reply to: ludesroc
Hi
In the BIN folder of the installed application, there is an Intent.config file. For just in case, create a copy of this file.
Open it in your favorite XML editor, and change the following section in the desired way. The <Args> node may contain relative or absolute path to the library.
    <Library name="userlib">
      <Args>..\Library\userlib\</Args>
      <AutodeskProvided>True</AutodeskProvided>
      <Locked>True</Locked>
      <PrettyName>User Library</PrettyName>
      <Type>TextFile</Type>
    </Library>
For older Intent versions, the similar can be set in registry
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Intent\R<version>\Intent Common Files\Libraries\userlib
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
ludesroc
in reply to: AlexKorzun
Great thanks Alex!
Ludesroc
