Inventor Engineer-To-Order (Read-Only)
Welcome to Autodeskā€™s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Showing results forĀ
Did you mean:Ā
ThumbnailPath in UIPartMixin
2 REPLIES 2
sebastiancordes
543 Views, 2 Replies
can anybody tell me the purpose and behaviour of the parameter ThumbnailPath in UIPartMixin?
IconPath is obvious and works fine, but I can't figure out on the other one.
Cheers
Sebastian
2 REPLIES 2
Hi Sebastian,
Thumbnail path is used in the "AddChildView" control on the web, and in the "ConfigurePartForm" control in Inventor. We currently don't use these controls in our samples.
Scott Anderson
Principal Software Engineer
Thanks for the answer!
I finally got the message and it solved my problem thru the API of the UI.
Sebastian
