Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Sorting chain of balloons.
2 REPLIES 2
Lesoux
424 Views, 2 Replies
Is there some way for sorting chain of balloons on the drawing by ascending?
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Inventor 2020.3.4, Build 373
2 REPLIES 2
Jon.Balgley
in reply to: Lesoux
I am assuming you are talking about "attached balloons", like this:
As far as I know, this is not supported by ETO.  But you can change the numbers in the attached balloons using the Inventor API. The key thing -- apparently -- is that the so-called "attached balloons" are represented by an API object called "BalloonValueSets".  Each attached balloon is an instance of "BalloonValueSet" (singular) within the "BalloonValueSets" (plural) collection.  To create attached balloons, you use BalloonValueSets.Add.  You can use the properties of "BalloonValueSet" to change the number/text displayed in a particular attached balloon.
Hope this helps.
Jon Balgley
Lesoux
in reply to: Jon.Balgley
It's not supported by ETO only. Inventor doesn't support this feature too. But thanks for idea. I'll try to do that.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
