Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Sketchpart for IvAssemblyExtrudeFeature shows up in BOM
7 REPLIES 7
Message 1 of 8
tmckeand
577 Views, 7 Replies
I have a child rule that provides the sketch for an Assembly Extrude Feature. How do I keep this entity from showing up in the BOM?
7 REPLIES 7
Message 2 of 8
tmckeand
in reply to: tmckeand
Any Ideas on this?
Message 3 of 8
FarrenYoung
You might try,
isRef? = True
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
Message 4 of 8
tmckeand
in reply to: FarrenYoung
isRef? didn't work
Here some sample code
Child DoorAssy1 As (If door1? Then :DoorAssy Else :NullDesign)
        DefaultBOMStructure = :Phantom
        doorHeight = Me.door1Height
        doorWidth = Me.door1Width
        fourSided? = Me.fourSided1?
        doorNum = 1
    End Child
    Child doorAssy1BottomMate As (If door1? Then :IvMateConstraint Else :NullDesign)
        part1 = DoorAssy1.bottomEmbed_1.plate141018
        entity1 = "BottomFace"
        part2 = BOTTOM
        solution = :mate
        offset = 0.0
        showInModelBrowser? = ShowConstraints?
    End Child
    Child doorAssy1GroundMate As (If door1? Then :IvMateConstraint Else :NullDesign)
        entity1 = "GroundFace"
        part2 = Ground
        solution = :mate
        offset = 0.0
    End Child
    Child doorAssy1LeftMate As (If door1? Then :IvMateConstraint Else :NullDesign)
        part1 = DoorAssy1.doorFrame
        entity1 = "LeftFace"
        part2 = Left
        solution = :flush
        offset = -door1Placement
    End Child
    Child Door1Cutout As (If door1? Then :DoorCutout Else :NullDesign)
        Width = door1Width
        Height = door1Height
    End Child
    Child door1CutoutLeftMate  As (If door1? Then :IvMateConstraint Else :NullDesign)
        part1 = Door1Cutout
        entity1 = "SketchLine1"
        part2 = DoorAssy1.doorFrame
        entity2 = "LeftFace"
        solution = :mate
        offset = -2.0
    End Child
    Child door1CutoutBottomMate  As (If door1? Then :IvMateConstraint Else :NullDesign)
        part1 = Door1Cutout
        entity1 = "SketchLine2"
        entity2 = "LeftBottomFace"
        solution = :mate
        offset = 2.0
    End Child
    Child Door1Opening As (If door1? Then :IvAssemblyExtrudeFeature Else :NullDesign)
        sketchPart = Door1Cutout
        sketchName = "DoorSketch"
        extentDirection = :Positive
        distance = wallThck
        participants = participantList
    End Child
Message 5 of 8
tmckeand
From the above code, is there a better way?
Message 6 of 8
FarrenYoung
Where did you try placing isRef? = True
 It should go on the Child "Door1Cutout"
Alternatively, you could specify the default bom structure on the factory file as reference.
--Farren
Message 7 of 8
Jon.Balgley
Not sure if this will do the trick or not, but: there's a "bomStructure" parameter.  Supply a value of :Reference.
You would probably embed this as a non-Parameter rule in your DoorCutout design, as opposed to supplying it as a Parameter in this assembly.
Jon Balgley
Message 8 of 8
tmckeand
in reply to: Jon.Balgley
I got this working!
I moved the sketchpart for the doorCutout to the DoorAssy design, for which DefaultBOMStructure is set to :Phantom in the wall design, and added the bomStructure = :Reference parameter to the doorCutout child.
Thanks to everyone for helping me run this down.
