Does anyone know how to save files in a non read only state? When ETO creates the files in the Member Files location, it creates them as read only files. I want them to be editable.
Andrew
Solved by wayne.brill. Go to Solution.
Hi Andrew,
Try setting EnablePartEditing? = True for the Adopted part.
This is the comment from %%IvAdoptedPart:
' by default, we prevent member parts from being edited, since such edits would be lost if a new member were to be
' regenerated due to a reason such as factory file change. This rule allows the user to override this behavior.
Wayne
