I have installed this (twice now) but when I run Visual Studio and open an ETO project, and then hit debug (F5) the systeem says Starting Inventor and Intent. But they don't.
Anyone any ideas?
Royston
Did you have Visual Studio installed before you installed ETO 2014? If not, ETO will install Visual Studio Integrated Shell 2012. Is that the software that you're using?
Yes it is the integrated shell of VS 2012 that I'm using, or rahter trying to use.
I am on Windows 7 64 bit, and have VS 2010 installed from previous ETO install.
Royston
Hello Sascha,
The problem described by Royston has been fixed in Inventor ETO 2014 SP1. There is a possibility that it will also fix the issue that you're describing.
If you still see the same behavior after installing SP1, please try the command File > Import Inventor Project. Does that show the same error message?
Sascha,
Please try these steps. Open a Command Prompt window and enter the commands:
cd C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\IDE
devenv /setup
I have the same issue, that i don't have the possibility to choose "Import Inventor Project". Is there any solution for this Problem, because my Inventor crashed always without any Error Message since i migrated from 2013 to 2014 and otherwise it is really difficult to find out where the error occurred. The Command Line Commands doesn't fix the problem.
