Inventor Engineer-to-Order
New Member
Message 1 of 2 (100 Views)
Please Help Cannot shell
100 Views, 1 Replies
11-30-2012 09:47 AM
I have been working on this part for a good amount of time and I just keep running into problems. One problem i am facing is no matter what I do I can not get a feature (this feature is blue in the "end" file and the surface that it comes from is blue in the "start" file) to extrude as a solid to the inside surface of the shell mock up (the shell mock up is the red feature). I can extrude it as a surface then thicken (this part is blue) but after I circular pattern the feature I cannot shell the combined group of features ( the features that need to be shelled are every color except red and the face that needs to be removed is yellow). The next problem is I need to delete the shell mock up, red part, but when I do that I am going to loose the extrude to surface feature and I don't know how to keep it. I have included two files the one labeled "end" is what I need the part to look like in the end (except the fact that it is not shelled to .2 in) which includes the the thickened surface in blue, the circular patter,green, and a magenta feature. The file named "start" is the where i started at and is included so it may be easier for you to help me. Any help on this is greatly appreciated and will help me not go insane.
If you want to know what the part is, it is a impeller pump shell for a submarine
Active Contributor
Chris_Rogers
Message 2 of 2 (82 Views)
Re: Please Help Cannot shell
12-03-2012 11:39 AM in reply to: pyro472
Hi pyro,
You may find more answers in the Autodesk Inventor forum.  http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
-Chris Rogers
Inventor Certified Professional
________________________________________________________
If this post helps, please click the "Thumbs up"/"Kudos"
If this post gives the solution, please click "Accept as Solution"
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
