I am having a problem setting a dynamic rule that is a long list. By long I mean the length of the string by doing .ToString() on my Intent.Value I get over 4000 characters.
Upon further investigation I have found that it may be more related to the parsing of a string over a set limit.
I have created the following method to demonstrate the problem with a simple string. The results follow.
Method TestError() As Any
Dim str As String = ""
Dim i As Integer
For i = 1 To 5000
str = str + "x"
printValue(length(str))
EvaluateString("""" & str & """")
Next
Return NoValue
End Method
1
2
4003
4004
4005
11/1/2011 3:32:19 PM: Error message: Parse error
Error code: 20008
Error occurred: Error
Rule Stack:
Root - %%EVAL_TEMP_9108
Root - TestError
Is there a setting somewhere to adjust this? Is it possible you could increase this limit or give user an option to?
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
