Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
MarkBrouwersIntent
314 Views, 5 Replies
IvAutoCADBlock
I'm trying to get the design IvAutoCadBlock to work the way I want. I want to use the parameter librarydocument to be able to change my autocadsymbol outside Inventor. So I created in Autocad a drawing (named drawing1) with a block 'circle' and gave that block an attribute named ArticleNumber.
In ETO I created a childrule :
Child Autocad_Symbolen As :IvAutoCADBlock
		libraryDocument = "D:\WorkingFolder\drawing1.dwg"
		sheet = Parent
		definition = "circle"
symbolorigin=point(0,0,0) PromptTextValues = {{"ArticleNumber","a specific value"}} End Child
 Then I get in ETO following error :
 Could not import AutoCAD block definitions from 'circle': Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Inventor errors:
 Invalid input for Request.
 But when I import the Autocadblock in my standard drawing template, the code works execpt for the attributes. I can't manage to give the attribute Articlenumber a specific value.
What am I doing wrong ? Someone a codesample ?
Cheers,
Mark
5 REPLIES 5
Can we get the versions of ETO and AutoCAD that you are using?
Jack,
The version I work with :
ETO
Autocad
Autocad 2013 (product version G.55.0.0)
Cheers,
Mark
Anyone any ideas/thoughts ?
Cheers,
Mark
From the information given, we can't determine what is going wrong.  Could you file this problem with support at A.D.N?  If we can replicate it here, we can find out what the mystery error is.
MarkBrouwers
in reply to: JackGregory
Jack,
I've opened case 09441549 and attached a visual studio project. Hopes it helps.
Cheers,
Mark Brouwers
