Inventor Engineer-to-Order
FarrenYoung
Message 1 of 2 (175 Views)
IvAssemblyExtrudeFeature not working in 2012 build 322, but works in 2013. help?
175 Views, 1 Replies
08-16-2012 03:52 PM
I read several posts here regarding this design not working in various builds, but from what I gathered it may or may not have been fixed in 2012 build 322.  I tested it in 2013 and can confirm the exact same project/code/assembly will work just fine.  I believe Tom mentioned getting a fixed inventor.dll from ADN to fix this problem, is it possible I could get the same?  I'm at the end of a project and switching to 2013 is not an option.
My Inventor.dll version is 5.1.0.322
Design CylindersAssembly : AssemblyExtrudeTestRoot IvAssemblyDocument
    Child VerticalCylinder_1 As :VerticalCylinder
        ignorePosition? = False
        grounded? = False
        origin = Point(0.0, 0.0, 0.0)
    End Child
    Child CircleSketch As :CircleSketch
    End Child
    Child CircleExtrude As :IvAssemblyExtrudeFeature
        sketchPart = CircleSketch
        sketchName = "Sketch1"
        extentDirection = :smileytongue:ositive
        distance = 400
    End Child
End Design
--Farren
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
Board Manager
sanjay.ramaswamy
Message 2 of 2 (139 Views)
Re: IvAssemblyExtrudeFeature not working in 2012 build 322, but works in 2013. h
08-17-2012 12:48 PM in reply to: FarrenYoung
Farren,
Unfortunately, we do not have a fix for this issue for the 2012 version. We are not aware of the dll fix that you are talking about, but it is unrelated to this.
If this issue is critical, please communicate this thru the ADN support channel and provide a business justification.
thanks,
Sanjay-
You are not logged in.
Manufacturing Community
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
