I have build my ETO Intent addin. It works with my Inventor OEM, but I have Autodesk_Inv_ETO_Srs_2014_Eng_64bit installed on that computer.
The problem rises after I build my own installer with OEM Configurator.
Regards
Tomas
Solved by wayne.brill. Go to Solution.
Hi Tomas,
Can you let me know if you have you used the ETO Series Install Builder?
There is a topic about this in the help file:
You can launch ETO Series Install Builder from the start menu. (Under Autodesk> Autodesk Inventor ETO Components 2014)
Using the ETO Series Install Builder should create an install that will install everything needed for an ETO solution on a system without any version of Inventor previously being installed.
Wayne
That would be great.
The problem is that i receive "The path is not of a legal form." error after hitting first "Next button" of ETO Series Install Builder.
Just to clarify: I have tested ETO Install Builder with the working iOEM configuration file from iBlock example (I mentioned above) and I receive the same "The path is not of a legal form." error.
I can't provide a screenshot right now (I'm using Windows7 different than English at the moment) but the error will appear also on Win7 EN, after I just click "Next" on the same window of above picture.
Hi Tomas,
There is a discussion group post where this error was reported. (link below)
From that post:
"Figured out what went wrong. During OEM Configure, I must specify System Icon."
Please check if specifying the System Icon in the OEM Confugurator solves the error in the ETO Install Builder.
Wayne
Thank You Wayne!
Now I have my deployment working.
