Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Message 1 of 14
Jon.Balgley
1796 Views, 13 Replies
Inventor ETO 2015
Autodesk is happy to announce the release of Inventor ETO 2015.  This release is compatible with Inventor 2015, Inventor OEM 2015, and Vault 2015.
As always, you can communicate with us here on the newsgroup.
Sincerely,
The Inventor ETO team
Jon Balgley
13 REPLIES 13
Message 2 of 14
masureb
in reply to: Jon.Balgley
on the sub center, I've just access to 2015 version with Autodesk Inventor Engineer-to-Order Series.
Do you know when Autodesk Inventor Engineer-to-Order Server will be available?
Cheers,
-Bertrand
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Message 3 of 14
chad_boss
Hi Jon,
I'm an ADN member. Could you tell me where I can download ETO 2015? We are currently working with Autodesk consulting on a project and I'm having a terrible time even finding Inventor ETO 2015.
Chad Boss
Herman Miller, Inc.
Message 4 of 14
glibardi
in reply to: chad_boss
Chad, Here is a link provided by the ADN team to get Inventor ETO. http://adn.autodesk.com/adn/servlet/index?siteID=4814862&id=17219252&linkID=4900577 I hope this helps, Gene
Message 5 of 14
chad_boss
in reply to: glibardi
Thanks. Finally got it downloaded.
Message 6 of 14
ludesroc
Hi John, Is there a What's new document somewhere? Regards,
Ludesroc
Message 7 of 14
Jon.Balgley
in reply to: ludesroc
I don't think there is such a document.  Inventor ETO 2015 was a maintenance release to support Inventor 2015 and related systems like Vault.
Jon Balgley
Message 8 of 14
CarlosOR
hello jon
There is a ETO team in Spanish????
Message 9 of 14
Jon.Balgley
in reply to: CarlosOR
Hi --
No, there is only support in English.  But we can use Google Translate!
No, no es sólo un apoyo en Inglés. Pero podemos usar Google Translate!
Jon Balgley
Message 10 of 14
qcl15849580524
hello, chad_boss, I am so embarassed to ask, I only have an student account so I couldn't login https://www3.autodesk.com/waca/servlet/login?url=http://adn.autodesk.com/adn/servlet/index%3fsiteID=... to download it. would you borrow me a ID and password? I will be so grateful for your help.Thanks in advanced.
Message 11 of 14
where else can i download inventor ETO or ETO series or ETO server, in my situation, I only have autodesk Inventor 2014 professional, Thank all of you!
Message 12 of 14
philip.s
in reply to: qcl15849580524
You should be able to access the software directly from the Autodesk Virtual Agent 🙂
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
Message 13 of 14
williamqi77
in reply to: philip.s
dear I only have a student account, so i cant get access to eto series 2015, 066-66666666, 666-69696969 those serial no. would not work, would you please tell me what to do, thanks in advance, merci beaucoup
Message 14 of 14
williamqi77
in reply to: williamqi77
please see the attached photo, that is wht happened when i enter serial no.,     or if u had a correct serial no., would you send me the serial no.,   thanks so much for your help搜狗截图20141110211241.png
Please be aware that this is a public forum posting serial numbers or personal information is not advised
Edited by
Discussion_Admin
