Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Intent api get the refchain of a Component Occurrence object
1 REPLY 1
745 Views, 1 Reply
I'm building a user interface, and I'd like to allow the user to click on the part they want to add a child to.  When they click on a part, it returns a component occurrence.  How can I get the refchain of this ComponentOccurrence object?
The childName is NOT the same as the displayName, so I cannot use the display name.
Thank you,
Brandon
1 REPLY 1
AlexKorzun
Hi
HostAPI has a method that returns a ref string from the Inventor object:
string refChain = Autodesk.Intent.IntentAPI.Instance.HostAPI.HostApplication.RefChainFromHostObject( occ)
You may wish to feed the result into RefChain class constructor for further analysis.
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
