Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Extracting co-ordinates of a Point
2 REPLIES 2
695 Views, 2 Replies
Hello all,
I am trying to get the X-coordinate of a point.
The code goes something like this;
Rule lstStdPanelParameters As List
    Dim counter1 AsInteger
    For counter1 = 1 To intNoStdPanels
     lstStdPanelParameters = lstStdPanelParameters + {{ _
              ":origin", Point(counter1 * numStdPanelLength,0,0), _
              ":xDirection", Vector(0, 0, 1)), _
              ":yDirection", Vector(-1,0,0)}}
    Next
End Rule
The value I need in a spearate rule would be something like;
Rule pntFirstPanelOrigin As Point = Second( First _
( lstStdPanelParameters))
Rule intOriginX As Number  = pntFirstPanelOrigin.x
I get an error when I evaluate this (last) rule, saying "Found a Point, where a Part was expected"
I also get the same error if I use a child (for example)
Rule intOrigin2X As Number = myChildName.origin.x
Support for all the helpers is approaciated.
Thanking you,
Wajih
2 REPLIES 2
ebachrach
the function localx(origin) should give you the value you are looking for.
Elly
Elly Bachrach
ETO/CTO Solutions Designer
Intelligent Configuration Solutions
Mobile +1 (773) 401-6980
elly.bachrach@gmail.com
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
FarrenYoung
There are also hidden functions GetX(), GetY(), and GetZ() which you might find useful.  I believe localX() will convert the point relative to a coordinate system and GetX() will get the x value and not do any conversion.  Someone can correct me if i'm wrong.
--Farren
