Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Expired Application error
2 REPLIES 2
GeorgeWilliams
570 Views, 2 Replies
We have a project that is getting an Intent error that says "Expired Application" (attached image).  This error only occurs on a machine running the distributable version and they customer's subscription was not current.  The customer's subscription is now current.  What can we do to remove this issue?
George Williams
D3 Technologies - Automation Solutions
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
2 REPLIES 2
George, OEM applications must be built with the unlocked (purchased) version of ETO Series. The ADN version is locked, and any application built with the locked version time bombs at 30 days. There is no way to enable application past the 30 day time bomb.
Chris Palmatier
Customer Success Engineer
Inventor Engineer-to-Order
Thanks for the quick reply.
We did not compile the application with an ADN version but rather a paid version as this application has been running for some time.  With that said, I just found out that one of the guys might have installed 5.1 using the wrong serial number at the first of June that could have been used to generate a setup.
We will give it a go using the correct serial number now.
George.
George Williams
