I'm trying to use an other viewrep in my drawing, but I receive following error
The Child rule that I use for this
Child Top As :IvBaseView Model = Model viewScale = Scale viewOrientation = :Top viewStyle = :Hiddenline origin = Point(120,120,0) designViewRepresentation="ViewRep_DWG" designViewAssociative=true End Child
Am I doing something wrong ? If so, what is the correct way to work with designviews ? According to the documentation, I just need to specify the name of a designview as a string.
On my drawing I don't want to see all the parts so I tried the approach 'HiddenParts', but this is working to slow when his list has +100 parts in it. I now want to use this list of parts to switch off the render?-bit and than make a view and put this on the drawing. This works when I use the 'Intent'-viewrep.
Cheers,
Mark Brouwers
Solved by MarkBrouwersIntent. Go to Solution.
Solved my problem. Apparently I give the wrong reference to the paramter model.
The property 'designviewrepresentation' effectively works.
Cheers,
Mark
