Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
ETO Studio 2013 Delete Design
2 REPLIES 2
ludesroc
337 Views, 2 Replies
How can I delete a design from the Design Navigator window? There is no Delete command when (right mouse click) on a design.
Ludesroc
2 REPLIES 2
ludesroc
in reply to: ludesroc
Deleting the .iks file works. Is this the only way to delete a design in ETO Studio?
Ludesroc
Jon.Balgley
You can delete designs (IKS files) using the Solution Explorer window ... but only when Inventor is not running.  That behavior is in sync with how other languages work in Visual Studio, i.e., you can't remove files from the solution while it is running.
It is possible to add new designs/files while Inventor is running (unlike other languages), using the Design Navigator.
Jon Balgley
