I've installed ETO R2 and am experiencing a number of issues already. I was hoping someone else would be able to confirm them or help me fix them.
At this point ETO Studio is still unusable to me. I would appreciate it if this was officially responded to. If need be, I can open an ADN support request.
Hi --
If you could file an ADN report, that would be great. That way it will be tracked. We can report the results here, as appropriate.
We will begin looking into these issues immediately, of course.
--Jon
Thank you for looking into this. For reference, the case number is: 07990084
For everyone's information:
We are continuing to investigate these problems with help from "bsee1".
The simplest problems that "bsee1" reported, i.e., problems with the "help link" and "install builder" buttons in ETO Studio -- these appear to work OK, both on QA "clean machines" and multiple users' systems here at Autodesk. At least for these issues, we will probably find that there was some unusual factor in the environment that we didn't consider.
We encourage other folks to install "R2" and try it out, and if you have problems, let us know. It will help everyone if we can get more data points.
--Jon
Is anyone using the "StoreModelExternally" option with R2?
Just installed R2 on a Win7 64 bit computer and the ikp file is no longer being used.
Inventor SP1.1 was installed prior to the ETO R2 install.
Pete
Autodesk was very helpful in getting the issue resolved. The issue was due to a conflict with the Visual Studio addin Resharper. For anyone else with this issue, disable Resharper while working in ETO Studio. I'm hopeful for a permanent fix, but disabling Resharper will make everything work for now.
Hi Pete,
The setting has been moved to Intent.config file (located in BIN folder of the installation).
Setting name is StoreModelExternally, its value should be 1 for your case.
For just in case, please make the safe copy of Intent.config before changing it.
See more info in What's new
