In my ETO application I generate successfully ETO driven IDW's.
When I save the IDW's as a DWG file (by ETO rules) sometimes a ZIP file is generated.
I would like to switch off this behavior.
Who can help?
Dieter
Hi Dieter,
I am not finding a setting for this. Are you using ETO Series? (which version?)
Could you provide a small dataset I can use to recreate this behavior? (If you are an ADN member you can log a case if you want to keep it private)
Wayne
