Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
ETO IDW saved as DWG builds a ZIP file
1 REPLY 1
intentdesign
398 Views, 1 Reply
In my ETO application I generate successfully ETO driven IDW's.
When I save the IDW's as a DWG file (by ETO rules) sometimes a ZIP file is generated.
I would like to switch off this behavior.
Who can help?
Dieter
1 REPLY 1
wayne.brill
in reply to: intentdesign
Hi Dieter,
I am not finding a setting for this. Are you using ETO Series?  (which version?)
Could you provide a small dataset I can use to recreate this behavior? (If you are an ADN member you can log a case if you want to keep it private)
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
