Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
DevExpress License Required?
5 REPLIES 5
Radioflyer651
3586 Views, 5 Replies
This may sound like a stupid question, but in order to use the VS components (UIMessage, UIPartTree, UIPropertyGrid, IntentUIProject), do I have to purchase a DevExpress product?  When I add one of these components to my form, I initially get the dialog on the captured screen shot.
Did I skip over something obvious?
Thanks for your help,
Richard
5 REPLIES 5
Yes, that is correct. In order to use any of the "UI Tools" component in VS, you do need a DevExpress license. Note that end users of the application don't need the DevExpress license, just the developers using/creating these VS components.
Sanjay-
Just to clarify, only the UI Tools components for windows forms require a DevExpress license. One isn't required for using the Silverlight UI Tools controls.
Scott Anderson
Principal Software Engineer
Thanks for the clarification, guys.
Richard
bsee1
in reply to: sanjay.ramaswamy
That should probably be bolded in blinking red in the developer section.  I exaggerate, but as someone who has tried and completely failed to get UI Tools to work when developing with winforms, this would have been a useful bit of information.
Win7 x64 - 16gb ram
i7 3610qm
FirePro M4000
Inventor 2013
ETO 6.1
sanjay.ramaswamy
in reply to: bsee1
Sorry for the inconvenience. It was indeed an oversight on our part to not have called that out explicitly.
For the UI Tools - I assume you're aware of the "ETO 2013 UI Tools Tutorial" sample posted here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18361292&linkID=11268853
If getting a DevExpress license doesn't help you get thru that, we'd be glad to help you out.
Sanjay-
