This may sound like a stupid question, but in order to use the VS components (UIMessage, UIPartTree, UIPropertyGrid, IntentUIProject), do I have to purchase a DevExpress product? When I add one of these components to my form, I initially get the dialog on the captured screen shot.
Did I skip over something obvious?
Thanks for your help,
Richard
Solved by sanjay.ramaswamy. Go to Solution.
Yes, that is correct. In order to use any of the "UI Tools" component in VS, you do need a DevExpress license. Note that end users of the application don't need the DevExpress license, just the developers using/creating these VS components.
Sanjay-
Just to clarify, only the UI Tools components for windows forms require a DevExpress license. One isn't required for using the Silverlight UI Tools controls.
That should probably be bolded in blinking red in the developer section. I exaggerate, but as someone who has tried and completely failed to get UI Tools to work when developing with winforms, this would have been a useful bit of information.
Sorry for the inconvenience. It was indeed an oversight on our part to not have called that out explicitly.
For the UI Tools - I assume you're aware of the "ETO 2013 UI Tools Tutorial" sample posted here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18361292&linkID=11268853
If getting a DevExpress license doesn't help you get thru that, we'd be glad to help you out.
Sanjay-
