Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Deploying ETO to Inventor Professional 2015
3 REPLIES 3
639 Views, 3 Replies
We have been using eto projects (2014) without specific front end. Now we are trying to do same with 2015.
When we create deployment with Install Builder Wizard and choose Inventor Professional 2015 as host and
"no main executable" option is active everything seems to be all right.
Next we run setup in machine with Inventor Professional 2015 and again everything looks good.
But when starting Inventor there is no Intent.
All ETO-components in our custom deployment are installed, but ETO addin is not found in target machine.
And so Inventor is not aware of ETO.
What went wrong?
Waiting for help
Jouni
3 REPLIES 3
AlexKorzun
Hi Jouni
Sorry for the delay with the response. We are looking into a resolution or workaround for you.
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
psaarloos
in reply to: AlexKorzun
Hi Alex,
Is there a resolution for this issue? I am having exactly the same issue. (Workstation is running Windows 😎
Pim
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
in reply to: psaarloos
Hi "psaarloos"
We got new updated "deployment wizard" 1.7.2014 so Autodesk has solution.
Problem was that when you have windows with some other language than english (or at least finnish :)) that wizard goes bananas.
Wayne Brill send updated wizard and it needed service pack 1 to function, but now it is ok.
Regards Jouni Varis
