Hello Everyone,
I have a design similar to the conveyor example. what i am trying to do is create a custom design to get it to work with the Silverlight Plugins. Any help would be great. Basically i need to create a custom design using the conveyor example.
Solved by scott_anderson-adsk. Go to Solution.
In order to use the Silverlight plugin, you need to modify your application's designs. For example, parts need to mixin the UIPartMixin design and properties need to be created from the UIPropertyMixin design. See UI Tools for more information. You can also download other samples that use the Silverlight plugin on ADN.
I see that now but is there a way to convert the project to a UI project or do i have to manually create it file by file?
We don't have a tool to automate the process, so you will need to convert the files manually.
