Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Creating a Custom Design for ETO Server 2013 R2
3 REPLIES 3
scottdwagner
667 Views, 3 Replies
Hello Everyone,
I have a design similar to the conveyor example. what i am trying to do is create a custom design to get it to work with the Silverlight Plugins. Any help would be great. Basically i need to create a custom design using the conveyor example.
3 REPLIES 3
In order to use the Silverlight plugin, you need to modify your application's designs. For example, parts need to mixin the UIPartMixin design and properties need to be created from the UIPropertyMixin design. See UI Tools for more information. You can also download other samples that use the Silverlight plugin on ADN.
Scott Anderson
Principal Software Engineer
scottdwagner
in reply to: scottdwagner
I see that now but is there a way to convert the project to a UI project or do i have to manually create it file by file?
We don't have a tool to automate the process, so you will need to convert the files manually.
Scott Anderson
