Is it possible to concatenate child names?
Such as:
Child ("Bracket" + ItemNumber) As :Bracket grounded? = False End Child
Where ItemNumber is Parameter Rule inputted by the user.
Solved by FarrenYoung. Go to Solution.
Try
Child Bracket As :Bracket
Displayname = "Bracket" + ItemNumber
This works on how it is named in the Intent model browser. Is there also a way to change the name in the Inventor model browser?
Try. If your variable "ItemNumber" is integer or number you need to use function stringValue().
Parameter "occurrenceName" changes part or assembly name in the Inventor Browser.
occurrenceName = "Bracket" + stringValue(ItemNumber)
