Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
Color name with space is not accepted
2 REPLIES 2
chockalingam
618 Views, 2 Replies
When i added the choices for color as shown in image1.
The parameter dropdown is listed as in image 2.
Can any one guide me in providing values for choices.
Chockalingam
2 REPLIES 2
JackGregory
in reply to: chockalingam
I haven't looked into this in detail, but you can create a rule to build the choice list, and use %%EvalChoices to tell the system that the %%Choices string should be treated as a rule name to be evaluated instead of parsed as a list.  That way, you have more control over the list.
AlexKorzun
in reply to: JackGregory
Hi
You can specify the comma separator in the %%ChoicesDelimiter annotation.
<%%Choices("C1 color,C2 color,C3 color"), %%ChoicesDelimiter(",")> _
Parameter Rule theColorOld As String = "C1 color"
The alternative way to deal with your problem is something similar to:
<%%Choices("%%availableColors"), %%EvalChoices("True")> _
Parameter Rule theColor As String = "C1 color"
Rule %%availableColors As List = {"C1 color", "C2 color", "C3 color"}
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
