Inventor Engineer-to-Order
Distinguished Contributor
ludesroc
Message 1 of 4 (151 Views)
Accepted Solution
Client Graphic
151 Views, 3 Replies
11-01-2012 09:43 AM
I'm trying to add a simple text (client graphic) on screen...Can somebody point me in the right direction???
Child testCG As :CGText
Text = "Test"
AnchorPosition = Point(0,0,0)
AnchorCorner = :Left
visible? = True
position = Point(5,5,0)
Scalable? = True
Bold? = False
Italic? = False
Font = %%InventorApplication.GeneralOptions.TextAppearance
FontSize = %%InventorApplication.GeneralOptions.TextSize
HorizontalAlignment = :Left
VerticalAlignment = :BaseLine
End Child
I get :
Exception in function cg_drawText
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Luc
Ludesroc
Board Manager
Message 2 of 4 (142 Views)
Re: Client Graphic
11-01-2012 05:27 PM in reply to: ludesroc
Hi --
This is under investigation ... apparently there are some defects in this area ... try different values for :VerticalAlignment ... more information tomorrow.
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Autodesk, Inc.
Employee
Message 3 of 4 (125 Views)
Re: Client Graphic
11-02-2012 09:33 AM in reply to: ludesroc
As Jon mentioned, there seems to be a defect in CGText VerticalAlignment.  If it is set to :BaseLine it will fail.  But if you set it to one of the other choices (Middle, Upper, Lower) it seems to be ok.  I will look into this further and file the issue in our tracking system.
Also, the choices for AnchorCorner are: None, TopLeft, TopRight, BottomLeft, BottomRight.  You have it set to :Left, which is not a valid choice.
Child TheText As :CGText, Quantity =  Quantity2D
	Text = "Test"
        AnchorCorner = :None
        visible? = True
        Scalable? = True
        Bold? = False
        Italic? = False
        VerticalAlignment = :Lower
	End Child
-Casey
ludesroc
Message 4 of 4 (118 Views)
Re: Client Graphic
11-02-2012 10:27 AM in reply to: Casey.Motherway
Works great!
Thanks Casey!
Ludesroc
You are not logged in.
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
